my quick release is back to Sparco, again! it just had a ''little'' play on the shaft lol
https://www.youtube.com/watch?v=S6EOD7Ah7cU
every part I order is just incorrect, broken or doesn't fit lol
I like this!!
I need a 40mm spacer now that I've moved my seat back for the pedal box, so I looked at this Sparco quick release but I think I will go with the Lifeline, well I'll fit a spacer first and then fit a lifeline if I like the steering wheel position.
thnx:thumb: if you want to buy an life line quick release, take a look here:
http://www.rallyshop.it/index.php?ma...sort=4a&page=3
That's because they're the same as the ones on ebay for £23
Sorry you're right it is BS
http://www.rallyshop.it/images/volanti/015R98TU.jpg
Is the same product as:-
http://www.ebay.co.uk/itm/Car-Black-...-/262310660039
And these can be had for £14 not £23
MY MISTAKE
I think what WideGhost means is that they look the same, which they will. That's sort of what happens when a genuine item is given to a Chinese machine shop for copying.
I can't tell the difference in quality or material spec just from those pics. I would wage on only one of them snapping in an accident though.
I'll be buying the lifeline one!!
The cheap ones are cheap for a reason, they're shit!!!
They may look the same but the are completely different. There's a reason rally teams use £200 lifeline ones and not £14 sparco ones!!!!
Point being 230 euros for a quick release with play in it says it all.
Spend your money on whatever you want, but I promise you they're made from exactly the same materials constructed in exactly the same way.
As i've said before HEAVEN FORBID SOMETHING BREAKS IN AN ACCIDENT.
