Originally Posted by
kevy.m
Hi Ian I always thought the valves were the same ??? but I don't know either.
I'm sure you can fit 1.1mm oversize valves on the xe head but 2mm is the max & the seats need redone
but I'm not 100% on the difference's on the heads & cams so maybe someone else will come along with more info??
I have heard about fitting a xe cam to the let head cant remember if it was the inlet or exhaust I'm assuming its the exhaust??
Regarding the ZLET oil pump how is the pick up modified & does the let engine come with a baffled sump or does this come
from another engine??
Thanks Buddy
