Thanks mate, for the first time ever, Iain was actually complimentary of something I'd done!!!
As for FPR, I've got an FSE, same as I'm running now, I only run 1.9 bar fuel pressure so it's not doing loads of work.
I think your clutch pedal has tweaked my calf you know....
Nice car tho, i enjoy it.
So few things have gone on here.
As previous posts explained wheel fall offage at Mallory, Housey not a happy boy, emergency hubs from Conor as we know, fitted so we could get to PVS, which we did.
As I was sick of people telling me the ratchet straps (that were a temp measure) holding the tank, were the most unsafe thing in the history of car building and I should flog myself with 9 cats or whatever people got whipped with in the olden days. I decided proper tank mounts were required.
http://i27.photobucket.com/albums/c1...2E223CE651.jpg
Much happier and no comments from bellends at PVS!! I intended to remove the box and lower it as much as possible into the well but the chap that sent me the angle only sent 1 length instead of the 4 i ordered, so I've ordered more and once the tank is out of fuel I'll smash it on the proper angle mounts.
As you can see in this pic, rubber hoses for the FPR, I'd ordered an FPR with AN-6 fittings, decided to move it back up to the bay.
http://i27.photobucket.com/albums/c1...3B95FDDC41.jpg
Crap pic for some reason!! Wheel well looks so much better with all the proper AN-6 lines
http://i27.photobucket.com/albums/c1...DC383731B6.jpg
This is so much more gooderer. Made some changes to the lines from the bulkhead too, much prefer how they look
http://i27.photobucket.com/albums/c1...DB47563037.jpg
Next up, it seems the one billet one plastic brake resoviour was the most hilarious thing the weed smokers at PVS had seen, got bored so banged the other one I had on
http://i27.photobucket.com/albums/c1...F3B3DA753A.jpg
Proper lines fitted from the M/c to the solid lines, so much happier with this now.
http://i27.photobucket.com/albums/c1...D10FD5FFF6.jpg
Onto today, left the house at 6am, quick 280 mile round trip to Norwich and back with the trailer to drop some parts at the office, stopped at B&Q to get some gravel, decided to neaten things up for the neighbours
http://i27.photobucket.com/albums/c1...12D16EEDC6.jpg
http://i27.photobucket.com/albums/c1...A732BC3AAC.jpg
http://i27.photobucket.com/albums/c1...DD3417A499.jpg
It's not technically my land so I wasn't wasting loads of money incase someone kicks off, but it looks better
With that done and the 24hr Le Mans on the laptop, got started on the car. HHMS machined hubs arrived, decided to get them to build them up with studs for me, studs are lovely!!!
http://i27.photobucket.com/albums/c1...C6446836E0.jpg
Got them on the car, lovely jubbly until...............
http://i27.photobucket.com/albums/c1...134ABD5246.jpg
Disc doesn't go over the shoulder on the stud, quick call to Hockly, "Same studs we use on all our Vauxhall applications" Hmmmmmm
http://i27.photobucket.com/albums/c1...E779C964D8.jpg
Stud shoulder, forgot to picture the disc hole but it was 13.3mm, luckily my mate in Norwich is an engineering gangstar, found me a 9/16 drill bit, which is 14.25. So.....
http://i27.photobucket.com/albums/c1...3C5CBE06FB.jpg
Disc adjusted. Then fitted, jobsagoodun, well it was until
http://i27.photobucket.com/albums/c1...C8A0088C5B.jpg
Wheel doesn't fit either!! Quick call to Iain to see what he thought, bosh, drilled the wheel out, all the work is done by the countersinking on the wheel against the nut so the hole in the middle isn't overly important aslong as it's not a wizards sleeve.
So there we go, all done.
Turned my hand to the dials which I've not been happy with as it kept bending, made this 3mm alu plate up, just brushed it over with the grinder to take the shine off, hoping it'll oxidize and dull up and then I'll lacquer it. Really happy with the little angle bracket mounts I've made to hold it, even if I do say so myself!!
http://i27.photobucket.com/albums/c1...3AAF3EE93E.jpg
Great build this, going to copy the filler pipe out the window I think :thumb: lol
I think you just enjoy winding people up as I honestly can't think of any other reason to fit just one billet brake fluid reservoir lol, though you really need to put some effort into checking fluid levels now!
I can't figure out why you didn't install the pedal box tight to the wheel arch to give a better position, but as I've said elsewhere different folks etc ;)
How much the the HH hubs work out in total? I need another set for my Purple LET - I assume you went for the big block flanges and big bearings?
Mr Tall, I've never really been bothered by the steering wheel position being offset, my aim has been to get the brake pedal below the middle of the steering column as it is, I can't be doing with moving the column, on this shell atleast. As for the pedal box location, this is an interesting one, I spent a long time discussing it with Iain, I tried to get it onto the bulkhead and it just didn't work, the pedals were wonky and the steering column would have been in the way of the brake pedal. That being said, since I've fitted mine I've seen the black euro nova that's being subaru'd and he has the pedal box hard on the bulkhead. So........ it'll be floor mounted for the new shell, get it done properly.
As for the resovoiurs, I had to fit the billet one as my pressure bleeder wasn't doing the business on the plastic one, needed to get to Mallory and ran out of time to fit the other one. I don't set out to intentionally wind people up with these things
Yeah went for the machined knuckles with the Audi 80 bearings, I wouldn't ever run a big block with the machined down hubs again, downright dangerous, I can't bleieve Elderkin actually helped me put them together, I reckon he did it on purpose to try and kill me cos he's scared I'm getting quicker round track!!
The whole lot came to £210, I supplied bearings, knuckles and the new hubs, they supplied studs and nuts and assembled them up.
Numbers if you're interested
Hubs :- Febi 0326194 £27.31 each from ebay http://www.ebay.co.uk/itm/3317597225...%3AMEBIDX%3AIT
Bearings :- Febi 3620 £16.31 each from ebay http://www.ebay.co.uk/itm/1910854998...%3AMEBIDX%3AIT
Today was a mixed day, didn't go to bed til 1.30am as the 24hr Le Mans was on, was up again at 6 to carry on watching. As the sun was shining we took the new dog down to the beach where he attempted to dig his way to freedom. I hate sand.
http://i27.photobucket.com/albums/c1...5F3246B8_1.jpg
Anyway enough namby pampy pussy shite.
http://i27.photobucket.com/albums/c1...C730A008D8.jpg
Gotta love coffee table working!!
http://i27.photobucket.com/albums/c1...D851C6FFAF.jpg
Wired up with plugs on for easy disconnect
http://i27.photobucket.com/albums/c1...DCAC248DEF.jpg
Plugs added to the dash loom, few crimps used that will be soldered in the near future as I wasn't sure on a couple of connections.
http://i27.photobucket.com/albums/c1...102ECD99D5.jpg
Angle brackets added to the dash
http://i27.photobucket.com/albums/c1...D53E523DC6.jpg
All back together and working.
Also tried to work out a park feed for my wiper, but I think it's relay controlled and as I'm direct feeding the wiper motor I'll need to think about that one. Latching timer relay maybe.
