Are all the pipes getting hot? All piped up correctly? Was the car originally a 4 speed if so you will need to cut the white block down on the gear lever as it will hit and wont let you get the stick far enough over to get 5th.
Yeah all going the right places and they're getting hot
Check all the pipe ducts and controls if you had the dash out maybe something come loose or blocked somewhere.
Checked it all. Everything is as it should be, I'll check the heater control again. But if not then maybe an air lock
Was the car a 4 speed?
No mate 5 speed
Keep squeezing the main pipes while running with the heaters on full and go through the position settings may help.
Oh right take it you did the drill bit method when setting it up while moving the gearstick over as far as possible and tighten the bolt up!
Yeah mate that's how I set it up and still not got 5th.
Wondering if the selector fork for 5th it shagged
Strange pal usually works. Yeh maybe something is fcked.
