I did very similar. Kept the spi tank with the internal pump and swirl pot and made a 'straight through' pipe from the original pump. I think I welded a pipe clamp to connect it to to stop it moving about on the rubber, did you do similar?
Hi Iain, I had considered modifying the standard pump bracing arm, but because I've reversed the angle of the pick-up pipe and the single piece of cunifer seems to be stable enough. I've decided it doesn't warrant any further bracing. So just for a change I've not gone for the belt and braces solution lol
