Get them two cast marks aligned, check the leads are in the right place, and go from there
I have had it lined up like that pal,but then it wont rev or drive?? and just about ticks over?
ok will do that then tow it to some one to sort it i think
http://i1063.photobucket.com/albums/...5/seats014.jpg
this is massively advanced. the dizzy should be slightly retarded (as in just back from the centre point)
i'm guessing that something else is out of adjustment, like the idle mixture or the co level & it needs sorting.
how can i do this do you no the setting
your best bet is to get it to a garage & let them spend 1 hr on it.
have you checked your fuel pressure low fuel pressure would cause it to idle but not rev. i would of thought even with your timing slight out it should run drive and rev just maybe not the best also did you put the fuel filter on the right way because a filter the wrong way around can caused problems aswell
yea fuel filter is on ok thanks for the help but as mowgli said time to book it in
Cars still at the garage all timing been checked guy at the garage is now putting in an inline fuel pump, as he thinks theres not enough pressure coming from the intank pump, i hope this works, has anyone come across this??
You said this was a gsi, i we assumed it was a gsi installation.. I'd be surprised if you'd managed to get it to run without an mpi pump. Did it have a corsa/astra/daewoo intank mpi pump ?
