Right well seeing my new mounts are on there way to me I thought I'd better strip the oengine out of the old nova ready to swap across for a trial fit, got all wiring and plumbing disconnected so it's just a case of dropping the suspension and exhaust and it's out,
http://i706.photobucket.com/albums/w...1A386A1C_1.jpg
http://i706.photobucket.com/albums/w...6627AEF7_1.jpg
http://i706.photobucket.com/albums/w...1321F30F9E.jpg
http://i706.photobucket.com/albums/w...B4E9D073E3.jpg
http://i706.photobucket.com/albums/w...6A00967915.jpg
Just noticed that they did yesturday, although I copied the image code rather than clicking the picture thing on here
for some reason photobucket saying all my photos have been moved by me??
iphail lol
get it sorted, we need more pics
Just logged into pc photobucket and all my pics have vanished ? bloody crappy photo hoster
Photos back up and working again :)
and if all goes well should be picking up a corsa b Friday for its powersteering and servo.
bargain price so pays to buy the car rather than just a rack :thumb:
just need to purchase my self a welder next and I'll be well away
Right I'm off to collect a corsa b in an hour for its brake servo and pedal setup, epas coloum and I'm going to take the rack off aswell to convert to a nova, I'll get some pictures up when I've got it, nice scrap value car
Got myself a corsa b today to rape for a few bits and bobs. 5 door 1.2 gls. Amazed it's got electric mirrors, electric Windows and central locking lol, seemed a shame to rip it to bits as it was in good nick.
well I got it back and set about stripping the epas, brake pedal and servo and the rack aswell as it'll save me £100-£150 for a quick rack,
so so here's cars all lined up
http://i706.photobucket.com/albums/w...520A465F_1.jpg
no pics of it in bits I'm afraid lol,
one thing mind if anyone asks you to remove a steering rack with engine in and it's on a trailer tell them to kindy jog on, what a pita of a job that was, squeezing the rack out from behind the engine and I couldn't get underneath it cause of the trailer !!
well got everything off that I need here's the epas setup
http://i706.photobucket.com/albums/w...4DF9CAED1B.jpg
thinking of using the corsa clutch pedal aswell to save having to modify the nova one
Right then had a busy day today seeing as it was nice weather, decided to trial fit the let into my new shell to make sure everything fits as it should.
So i started the day like this let in one shell.
http://i706.photobucket.com/albums/w...35B3690784.jpg
http://i706.photobucket.com/albums/w...0965704D_1.jpg
then i set about dropping it through the bottom, with my little 1 ton jack and loads of blocks of wood as the jack doesnt go high enough to lift the shell over
http://i706.photobucket.com/albums/w...CB88D644_1.jpg
http://i706.photobucket.com/albums/w...015D3D9B_3.jpg
http://i706.photobucket.com/albums/w...80E84377B5.jpg
had an accident as i was dragging the engine on a block off wood across to the other nova, i had it on axle stands as i took the running gear off of it and leant against it and this happened
http://i706.photobucket.com/albums/w...1A6D646802.jpg
its on the move
http://i706.photobucket.com/albums/w...6194252B_1.jpg
http://i706.photobucket.com/albums/w...363DB03F52.jpg
You can notice in this picture with it almost in that the front engine mount has been altered, unsure what mount for thou!! caused me some issues anyway will show in pics
http://i706.photobucket.com/albums/w...6FBBAC13BF.jpg
in ready to lower shell
http://i706.photobucket.com/albums/w...3CA2B32E32.jpg
After about an hour of the inlet getting stuck on the steering rack bolts i decided to take the turbo off to give me some more room, Had loads in the old shell but none in this one !
http://i706.photobucket.com/albums/w...2D412715CF.jpg
http://i706.photobucket.com/albums/w...E69582774E.jpg
this gave me loads of room so i got it in on its mounts
http://i706.photobucket.com/albums/w...E64BCE1668.jpg
but as you can see here theres something not quite right
http://i706.photobucket.com/albums/w...C7E931BFB3.jpg
cam belt end looks to low to me ?
http://i706.photobucket.com/albums/w...5BBB8B7716.jpg
i tried slacking off the gearbox side to see if it would lower down as the shell has been adapted for the standard f28 mount but it wouldnt drop any lower because of the rear mount!
http://i706.photobucket.com/albums/w...F1962F2D_1.jpg
so some quick thinking came up with fliping the drivers mount so it sits on top of the bracket which then leveled the engine nicely
http://i706.photobucket.com/albums/w...8866B08C51.jpg
it sits level in the engine bay now but will the mount be alright like that?
http://i706.photobucket.com/albums/w...BB845B5D_1.jpg
