14 on a 16 block, i'm listening...
Buy a GTE head and a set of T40s and a good cam. Should give you a good bit of poke. Shouldn't cost a fortune either.
agreed. Dont poke around with 1.4 heads' especially that ebay link - the 1.4 nv is a 60hp thing, no good to u mate..Quote:
Originally Posted by Dod
GTE/GSi head will fit the 1.6 sv bottom end ; twin 40's shud net u more than the 32/34 carb, but ur lookin ?200-?300 for twin 40's... the cam, and i guess some figure around 120bhp shud be possible. But a dear, long winded way if u ask me; plus the f16(??) i think, box is pants , need a close ration jobbie. Its just so much more worth getting a gte/sgie lump and box, its unbelievable.
True, but even a SRI box would do the trick, 120bhp should be safe enough, but idealy a GTE item would be better. But if you're on a budget, 500 quid should see you well on.
your better off starting with a C16SE to be honest...
with a C16SE some 40's and a cam alone wont get you that much more than 120bhp, if that !
Really to release the potential you'l need some decent headwork and a decent exhaust system, right from the manifold.
however, these are later upgrades.
Yeah thats correct.Quote:
Originally Posted by Nick?
As already stated, c16se/e16se (1600 gte/gsi engine), t40s, cam 8)
where did u get the idea that i have a F16 gearbox in it, when i have an F13 :?
I didnt fit the f16 to big i think its a f 10 at the mo
The 16sv has a f16 wide ratio gearbox as standard.
it might have, but ive got an F13 on mine, its closer ratio than the F16
F13/F16 has nothing to do with the ratios its just an ident for the class of gearbox
the sv engine is shite due to its 1.4sr style cylinder head
to tune it fit a 16se head from a nova gte and stick some 40's on it, or even the original efi manifold if your concerned about fuel economy
