14nv, ok
if i got the dizzy, coil, ignition amp and loom from a nova with these in, it would be plug and play?
14nv, ok
Yes, that would probably be the easiest and cheapest method to get everything you need.
you could use the setup from any astra/cavalier with the 16sv carbed engine in ,it would be easy to come by from any scrappy ,only problem would be is there are 2 types of coil setup with the 16sv the early ones are similer to the 1.4 nova stuff and the later ones have a ecu mounted dead center on the bulkhead.
so if i go for the non ecu type im sorted?
cool, ill scour the scrappys on sat
even the ecu one would do the job its just a bit more wiring .
i think i got the ecu one, i havent a clue what i need, what i dont, and how to wire it in
this is what i got was off a carb 1.6 8v cav
http://www.corsasport.co.uk/carimages/7545/Image249.jpg
http://www.corsasport.co.uk/carimages/7545/Image254.jpg
http://www.corsasport.co.uk/carimages/7545/Image255.jpg
http://www.corsasport.co.uk/carimages/7545/Image252.jpg
http://www.corsasport.co.uk/carimages/7545/Image253.jpg
the multiplug scares the crap out of me, as i dont know how to wire it in, or if its right, or if i need the red cap bosh stuff instead.
this is a pain in the ****.
cut the multi-plug off and connect the red to a permanent live,the black to a switched live and the brown to a earth and it should run.
ive looked on my engine, and it has the same dizzy. so.
i gues if i connect up the map sensor. looking at the 2 other plugs, i connect up the coolent temp, 2 pin plug, and then give the ecu a live and earth that should be it? or am i being to simple
on the above loom i have starting and charging system, i can use the corsa one, i have reverse plug and oil pressure light and coolent temp for the dash. all those i gues i can leave off/cut out. and use the corsa stuff
any help greatly appreciated.
also..... the dizzy in the pic is the same on my engine, would a earlyer bosh-redcap dizzy bolt right upto my engine?
as the bosh system seem much simpler.
ok tookie thanks, so on the multiplug i connect those 3 wires to the corsa loom, "i think it has them on a 3 pin plug aswell"
i use the 2 pin coolent temp and map senor and octane plug as the ecu may need those for metering. but apart from that im done?
cool. ill try that
yeah keep the stuff you said and cut the rest out of the loom,you might want to keep the green wire thats seperate from the multi-plug as thats for the rev counter.
