Maybe next time you won't build things on a tiny budget.
Ouch! That reminds me of my freshly rebuilt X16XE going bang whilst give it large around Silverstone. In my case it presumably was a spun bearing shell (aluminium instead of proper material) used by the place that built my engine. Expensive failures, these!
Verstuurd vanaf mijn SM-A505FN met Tapatalk
Ultimately we can't pinpoint the failure, it was either a piston broke, rod little end let go or valve dropped which led to the first two in succession.
I can't complain, it's suffered 4 years of abuse and I've never had it out for a freshen up.
New engine will require yearly top and tailing (depending on use)
And the moral of the story is, use proper components, I've got a steel Arrow crank, Steel Arrow rods and we'll be using Omega pistons and Rec valves, all solid properly made stuff.
Double post
Is this done yet
Won't be long mate, just making a few changes to the steering wheel
https://uploads.tapatalk-cdn.com/202...783d0db28f.jpg
Will need someone to wire all this lot in too [emoji6]
https://uploads.tapatalk-cdn.com/202...b57d3bd0c1.jpg
Oooo, there’s some nice bits there
That are some very nice parts!
