I think the silliest option is the more appropiate
no they come inboxes of 2, i only ordered one, burtonpower forgot to take the other one out lolQuote:
Originally Posted by db_1.2
stu - did i read that right, your not using one on the 1.2T?
So how much you want for the other one baxter? Its a 13 row isnt it?:confused:
sold lol
Lol ok mate
might have used one on the 1.2T if when runnign it needed it. but as i cant be ****d to even get the N/A running lol
Lol ok Stu, ill let you know in about 2 weeks, got a fair bit of work to do:tard:
I own the cooler of baxter its a 10row which is required to run 2000CC or UNDER!!
yes you can run one on a smaller engine. BUT if there is no need ( and weve never seen the need for one in years of track abuse) then you can do more harm than good, if you use a thermostat then essentially your never going to make use of the cooler so its a waste of weight....
But for some one like me with a engine running over 1500rpm past standard its essenstial but you are right about cold oil dose more harm!!
