you should have connections for
coilpack
collant temp sensor on the right side of the head
lambda sensor (round single wire plug)
idle control valve
injectors
a few earths to the left of the injectors
plug for the sensor that goes in the inlet pipe
map sensor on the bulkhead
couple others ill post up when i remember lol
Ahhh cheers dude :) luckily the scrappy where i got the head from is pretty much right next to my house so i'll go and get the map sensor on friday morning when im back from uni! The only other thing im not sure about is the sensor that goes in the inlet pipe! I'll have to have a look at that again...
im sure ita a round plug, youll need the inlet pipe from the astra as it sits inside the pipe
