thanks for the info!!!!!
2 last Q's, i assume the brown/white isnt needed on the transponder? as it isnt needed on the 9 pin plug.
and i only put the brown/yellow to earth when i want to flash codes?
Yeah thats right the brown/white isnt needed and when you need to flash codes the ecu warning light flashes codes when brown/yellow is earthed.Quote:
Originally Posted by sri dave
There is a guide here.
http://www.topbuzz.co.uk/info/fault_...ault_codes.htm (your engine is GM-Multec MPi)
