Cool as fook imo :d
i want this done in mine
I did mine at the weekend as well,still wanted use of the glovebox so its pretty intact & the stereo is held with really strong double sided tape...surprisingly solid it is too.so i now have the original look but ipod connection,i just dont know where to put the cable? Any suggestions? lol i'm not leaving it dangling there :(
http://i932.photobucket.com/albums/a...68B80EB737.jpg
http://i932.photobucket.com/albums/a...68AC606657.jpg
http://i932.photobucket.com/albums/a...68B1EB233A.jpg
http://i932.photobucket.com/albums/a...68BD579E6A.jpg
Can you make it come out the centre console?
Aye lift your electric window switch housing up, run it through the back of the center console where the window switch wiring/plugs come through, then ream out a 4mm hole in one corner of the switch housing, sit the cable in there and clip back in, then you will have a flush fitting switch housing and a neat cable install, the iPhone or iPod will sit neatly (albeit upside down) in the front of the center console (or on its side) and be neatly plugged in and chargeable :thumb:
I wanted to avoid cutting the console but a small hole would be ok,cheers lads :thumb:
Its the way forward, stealth ice install :D .. Top job on the fabrication tbh :) might just consider this myself yet. I aquired a project with switch and button start. May just use stereo slot for switch panel or maybe inside glovebox.
Cheers for the ideas
