Ok well ill have to plug those back in and try it out, will my earth on the chassis leg have to be moved to earth on the back of the clocks then ?
+REP BraninsNova for the advice so far ;)
its easier and neater to join them all at the clocks inc the transducer wires.
Ok ill have a mess around with it tomorow and see what happens, thanks for the advice so far mate.
what aw06 done when he installed mine, was splice the digi plug on the loom, keeping the old plug. if i ever wanted to get rid of the digi.
and im sure as yours is a mk1, there are some differences.
pm him :D
did you get sorted with the digis? if not ill have a pop pver and have a look if you like?
if the indicator lights are on contstant (so not flashing like they should) you have an earth problem.. constant indicator lights is a + over the earth..
lewi. the digi dash should be a pretty much straight swap with the wire to the gearbox as an extra...
so you should be able to pick up everything off the haynes wiring diagrams
