what clocks did this have in?
None and the odd reminants of a fascia/dial/mileage reading. lol
lol ok bud cheers for replying
Hi I will have snowplough PMs sent
How are you removing the spoiler is it bonded and bolted on as removal can cause a lot if damage to the steel if you use a bar or screwdriver on it and I don't realy want the spoiler but don't want a dented boot ether and can you get pics if inside edges and any marks on the outsideplease
Spoiler is already off, has the original screw holes in the top that can be welded up, came off dead easy without any tools at all so I'll check nobody has damaged it taking it off previously and grab you some better pics.
More pics of stuff.
236mm vented brake setup (not ATE, what's the other caliper type?)
Coilovers, as I said brand new
http://iainel.co.uk/images/NovaBreak...Suspension.jpg
Full GM tailored carpet set, all four, slight wear through the edge behind the pedals
http://iainel.co.uk/images/NovaBreaking/Carpets1.jpg
mk1 crossmember trim pieces for those with a shallow bumper
http://iainel.co.uk/images/NovaBreak...memberTrim.jpg
Full stainless exhaust system, unsure on make, potentially a Mongoose system?!
http://iainel.co.uk/images/NovaBreaking/Exhaust.jpg
Clear indicators, LH headlight lense
http://iainel.co.uk/images/NovaBreaking/Indicator.jpg
Red ring steering wheel
http://iainel.co.uk/images/NovaBreak...eringWheel.jpg
Slabs, good condition, painted black, some marks on paint, tyres are scrap
http://iainel.co.uk/images/NovaBreaking/Wheel.jpg
The snowplough! Can't find any tow covers or trim bits so it's just the main carcass. 2 cracks where the vents are which could be easily plastic welded back together, think there is some slight distortion on the front too
http://iainel.co.uk/images/NovaBreaking/Snowplough1.jpg
One of the cracks on the right, other is similar
http://iainel.co.uk/images/NovaBreaking/Snowplough2.jpg
http://iainel.co.uk/images/NovaBreaking/Snowplough3.jpg
Tank and snow plow and fuel lines how much??
What condition is the bonnet in m8?
Iain, thst sytem looks like a magnex to me...
How much for clear indicators?
