Thought the engine mounts will be the same.. yeah but the nova driveshaft's will go into the box and corsa hubs?
You can use your nova shafts and your nova mounts and nova hubs.
But yeah the nova shafts will go into the Corsa hubs
You can use the legs
You can use the hubs and brakes
You'll need the nova shafts
You'll need the nova mounts, unsure if the rear gearbox mount is the same tho
It is the easiest way by getting a full car, so you know the engine runs and everythings there, you can also get the transponder loom out of the donor car too.
Ive got a full N reg, Corsa GSI, So stripping that and ive dropped everything out the bottom, ie. legs, coilovers, bottom arms, brakes... everything!
Cool, should be fairly easy then
Bottom arms are different as are the shafts
Ive dropped this little lot straight out the corsa, am i right in saying this is the c16xe?
http://i45.tinypic.com/ea2udf.jpg
The best way of telling usually is by the head, just under the rocker cover there will be 5 dimples that stand out, if all are even then they usually are C16xe's... If they're of different lengths then there usually a X16xe or X16xel
Will have a look tomorrow, Struggling to find a fuel tank and pump now! :(
Tank and pump here. PM me if still needed
