Thats looking spot on pal. Can you not ise the z20 head gasket and drill the rivets out same as they do with the c20let.
Only 1 issue i can see pal is the return into the sump could do with being further up i weld mine on so its practicaly touching the flange to stop oil backing up in there. Great work
Cheers pal I've heard the z20let wont work with the 8v not sure though without trying. I know the c20let one can be used with some modifications so will try. Thanks for the info re the oil return will sort that out at some point !
Been a while since I updated this I've been busy on the car painted wheels white and made a set of stubby mirrors plus made a single wiper for it. Need to get her out somewhere nice to get some decent pics soon instead of my drive haha. Cut out 45mm from mirrors and plastic welded back. They took a while to get right shaping up ect Glass was a bastid to get right it's not 100 percent but will do. Need to crack on with 8v turbo engine now..https://uploads.tapatalk-cdn.com/202...36abe1f057.jpghttps://uploads.tapatalk-cdn.com/202...50eb469d79.jpghttps://uploads.tapatalk-cdn.com/202...383bf45aed.jpghttps://uploads.tapatalk-cdn.com/202...f261f0af0c.jpghttps://uploads.tapatalk-cdn.com/202...9f854e83a7.jpghttps://uploads.tapatalk-cdn.com/202...b3d3441830.jpghttps://uploads.tapatalk-cdn.com/202...99c8c11945.jpghttps://uploads.tapatalk-cdn.com/202...05816c7698.jpg
Sent from my SM-A105FN using Tapatalk
I like those stubby mirrors but don't have nearly enough patience to make some!! Haha
Cheers they did take a few weeks off and on. Glad they are done haha
Have you filled the drivers side wiper hole?
When you put your wanted post up you reminded me I had my single wiper in the garage.... now really tempted to fit mine again.
I used a grommet painted white pal. Get it fitted you know you want to haha.
Oh I know I do bud.
