you need to use a gearbox with the cog drive, not with the gap gear as you have.
How many wires are on the tigra vss? 2 or 3? the option is to find a wiring diag that tells you what is what.
Oh bugger, so i presume ill also have this issue with my x16xe froma w reg corsa sport with f15??
Wire them up as you would the old style vss. :)
That's why I thought they would work, wire it up the same and see if it works. The N reg Tigra I broke had a cog drive F15, but the loom still had the plug ready for the vss. But the W reg 1.7d combo I put the V6 in had the electric vss, I thought they would just work the same tbh.
I think you're missing the point, if I use the standard VSS I won't have a speedo.
It will wire up to a digi dash
Cable drive speedo/vss with cog box, or gap gear vss with digdash.
I'm about to put a X16XE out of a Corsa Sport in my Nova. This is probably a stupid question but can I use the whole Corsa front "mechanical" end (engine, gearbox, hubs, brakes, driveshafts etc) and bolt it all into the Nova or are the Corsa's differant?
