vaux still sell the bulbs at £6 each but if they have none in stock you have to buy a pack of like 10 lol
bulbs can be bought from here
http://www.auto-essentials.co.uk/eco...10d-p-635.html
when you join the grey/green wires together do you then conect them to the live wires?
I never used to connect them just taped them up separate
hi any ideas why my lights are dimm
Dimmer switch turned down in your living room, muck on your headlights, blown bulb on your clocks, bike lights need new batteries?
I cant think of any other types of lights off the top of my head so hope my guesses contain an answer that might relate to you very vague and incorrectly placed question!
well what does the thread state ummmmmmmm oh yes i remember DIGIDASH yes
right ive wired it all up and re connected it and put it all back three times now and the main light that lights everything up is dim? if i look thru a gap i can see just one main bulb thats lite up. also i can get the left indicator to flash but not the right ive checked the bulb and the connection and the black/green wires are together. the only wires i have spare is three which are blue/yellow oil pressure, green rev counter and blue/red speed omiter. does any one no whats wrong thanks in advance
If you have joined the wires to the clock for your indicator tell tale, then there is your problem, you need to connect them to the wires on the stalk, and i would guess that one of the two main halogen bulbs that illuminate the dash, has blown and only half of the dash is being illuminated.
Although asking why your lights are 'dim' is not a very explanitory question is it, hence my vauge reply (which did contain my suspect answer, so i didnt just take the piss and not tell you)
ok well ive got indicators now and as for the illumination its is all the same dimmness if you no what i mean when the ignition is off i can not see anythin then when i turn ignition on it comes on dim ive joined the grey/green which someone stated that it makes it brighter also does not chaged when started and revved up to 5k
