What would give the most power then a 57i or the bogo air box attacked with a drill?
The K&N will give a much better sound and performance.
Plus the fact that a shiny engine bay looks nicer than a half hacked to death one! :-)
If you can afford the filter, get it, if not...do the hole idea. Cut about 10 holes equally round the box, to get enough air flow out the box.
Well maybe, but maybe not! If u use the modded airbox, u almost get as much power as the k+n, but if u use a k+n panel filter with the modded box, u get more than with the induction kit! Only prob is it doesnt look or sound as good!!
Dicko
remember you need cold air piping to get cold it into the bay
if you have a drilled box, will it not suck on unwanted crap?? I'd go induction!
You drill the box at the air entry side of the filter, so it still gets filtered by the pannel filter (is ther enough filters in there?)
