With the dash fitted. Cant get my drill in the gap, thinking if i belt sand the head off... Tried hammer and chiseling to try and turn it but it doesn't want to move....
Any tips?
Any tips?
I used a hammer and sharp chisel,
if you sand the head off you've still got to try and remove the rest of the bolt
Mine came out with a punch and a chisel, could weld a nut on if out the car or dash out
Punch and chisel the edge of it round mate, that's what I did!!
are you turning it the right way?
If i grind the head off, then the thread bit should be lose as the tension is gone... Well in theory..
i started to hit it with a hammer and chisel, i'll try again tonight making sure i hit it the right way.
Mig a 13mm nut on it. Spot the inner.
Again dash is in. Not much room to get a torch in there, plus fire risk.
Punch and chisel. I have got them off with mole grips a few times before.
Mole grips...........small?
Good ones!
