Push Pull Shifter Cables F13 F16 F20 Nova Corsa Cable Conversion with F17 Turret
http://www.ebay.co.uk/itm/Push-Pull-.../281853195564?
Item for sale is a set of shifter cables to convert a Nova etc to cable shift with an F13 / F16 / F20 gearbox, Vectra / Astra H Selector and Vectra C 1.8 F17 Turret.
This conversion is a bolt on job for everything except the cables as the standard vectra cables are too long. The spec/price breakdown of my cables (other sets not made yet so you can advise a length) is listed below. These are heavier duty than standard vectra cables for Fast Road / Track / Rally use.
40Series M16 Bulkhead Fittings Both ends, terminated M6, IP67 sealing grommet fitted.
Cable 1 1058mm - 85mm Travel - £36+vat
Cable 2 958mm - 65mm Travel - £36+vat
M6 10mm Ball Joint Socket - £3/each (4No. required)
IP67 Sealing Grommets to suit 10-13mm Cable, 23mm hole in bulkhead (final OD being 28mm) to suit 1mm bulkhead thickness - £3/each
Delivery is £12
Call me on 07801558308 if interested.
Also see how to guide with all info on how this is done.
http://www.pngclub.com/forum/showthread.php?211964-*HOW-TO*-Convert-F20-to-Cable-Shift-F17-Turret-(Morse-Cable-Bulk-Buy)
