Put a set of speedline alessios on my mk1 nova with coilovers and the tyre runs on the coil (quite low)
is this common? Should I just run a spacer to bring the wheel out a bit?
You can run a spacer to get the clearance or use shorter springs as that's what I have done with mine
Think the spring options is better idea so I can have bit more clearance on the arch, any idea what poundage sping rating for an ex engine to use?
You checked your not running too much camber??
Just a pair of technix coilovers, they have a camber adjuster at the hub bolting point so I'll have to get that set right before I can judge what is best I guess
Is it on the ground and touching or still jacked up?
You might find you have larger diameter springs. You really want the smallest (1.9inch iirc)
Or what size tyres are you running? you might just have wide tyres...
195 45's from memory
yeas was sitting on the ground and rubbed, will have to measure the coils
Widths are a little arbitrary anyway.... Depending on the brand they can be 5-10mm wider than stated lol
