what exastly would i need to make my c20ne nove into a c20ne turbo nove :d
turbo ????
pipe work ????
wiring ???
ecu ???? ect ect thanks
turbo ????
pipe work ????
wiring ???
ita all fairly easy and cheap(ish) untill you hit managment!! then its not worth it
This maybe of some use.
http://www.hg-motorsport.de/shop/pro...-8V-115HP.html
ebay manifold, turbo, oil feed/return, exhaust made to suit, jobs a good en on the cheap, oh n dont forget lower comp 2 gaskets or have a spacer made, upgrade injectors maybe, 200bhp + has been seen on standard management im gonna do it on my seh when i can be arsed
im sure the ne is the better starting point with low compression? could be wrong
im sure there is a 180 bhp ne turbo corsa b round my way, was posted on vauxsausage other week.
not thought of a b204 sabb lump? cheaps as chips for full car and ebay sell loom adapters for most vaux cars
200bhp+ mk 2 astra on mig a while a go but think that was 20seh
If using the c20ne, you can use a 1.9mm head gasket for the z20let engine. This should lower compression plenty. Injector wise, 1.8 or 2.0L ecotec ones should do the job. As trev said, 200+ bhp is easily achievable for not a lot of cash.
