Removing SRI engine loom
Hi all, can anyone help me out with the above?
I've unplugged everything i can including the ECU inside the car (behind the glovebox) but the engine loom appears to be riddled in with the car loom and i can't see how to remove it without cutting wires!
I recently removed a loom from an Astra GTE 8v where the ECU was inside the car but this was a simple unplug and pull out job.
Cheers, Tom
IIRC from reading Posts in here the 14 SRI loom is intertwined with the Cars loom and so isn't really reusable without massive heart ache.
Ideally you want a 14 MPi Astra Loom as its a seperate item from the cars loom.
I don't need to reuse the SRI engine loom i just need to remove it as i'm now running a GSI engine and i have the loom for that.
I cut all mine out mate. Was a bit of a headache with the old Haynes manual but what I was basically left with was a bunch of red (permananet live), black (ignition live) & browns (earths). Plenty of wires for add ons like guages ;)
Yeah I cut mine out too. It's not too difficult from a wiring point of view - the problem is that nasty goo they use under the loom tape, sticky as anything and gets everywhere!
I used a 1.2 carb car loom and spliced the 1.6's loom in to that. Nice and tidy, no wires left over.
Yeah it's all intertwined. By far the easiest way is to rip the lot out and put a carb/early loom in as the 1600 loom is self contained in the bay
Ok thanks for the help
I take it to replace the car loom the dash etc has to come out??
Yeah, right through to the rear lights.....
Though as The Simps says, removing the SRi motor loom from your car's loom if you can be bothered will leave you with lots of usefull spurs to run accessories, pumps, gauges etc. No bad thing.
