tried motor and stalk
might sound a bit stupid, but u got the right rating of fuse in there lol
other than that, all i can think of is track all the wiring used along the line and its connections, plus the earths for a good solid contact. also check the pins that the fuse touches, carrier bit might be melted up and bridging connection with something ?
is it the front or rear by the way, cant remember if they share fuses with anything else.. might be a prob with something its sharing causing it ?
have you checked the wiring to the horn
because this is also linked to the wiper fuse
had a problem with mine keep poping fuses and turned out to be
that the horn wire onto the steering wheel
was touching bare metal
What I was going to say. It shares the horn fuse.
front or rear if its rear check the wiring that goes through from car to tailgate isnt broken mate
