parts for sale
Here for sale is a c20let engine that has been fully rebuilt with no expense spared!
price £1900 ono
Spec list below
Block-
• c20xe early type block, re-bored to 86.5 with 3 tho clearance on the bores all work carried out by CNC heads ( Ric wood)
•fully decked, acid dipped and painted in high temp black paint.
•oil feed blank professionally drilled and tapped to accept the original let oil return fitting.
• mahle 0.5 oversize pistons with new rings properly gapped, standard let conrods with ARP 2000 bolts.
• ACL race big end bearings, standard size.
• mahle mains bearings, standard size.
•early c20xe crank, balanced and polished.
• Brand new late timing belt kit, water pump, crank bolt and genuine brand new backing plate all supplied by Autovaux.
• Brand new 2.0 8 valve baffle plate, Autovaux.
• brand new c20let oil pump, Autovaux.
• victor reinz crank seals.
c20let standard oil cooler sandwich plate with pipercross oil filter
standard c20let pot type flywheel with helix clutch, used.
Head-
•c20let GM head , fully rebuilt , porous mod done with stainless sleeves.
• fully ported and polished to a very high standard!
• autosprint bronze valve guides, brand new autosprint lifters.
• brand new genuine GM valve springs and retaining caps.
• skimmed by CNC heads ( Ric wood) 1.5 tho
• fully rebuilt by Ric wood including installation of all new components.
• c20xe inlet cam , standard c20let exhaust cam.
• brand new Kent vernier pulley in blue, square tooth on the inlet cam.left at 0 degrees up to the new owner to retard it 6 degrees.
• brand new RS turbo spark plugs.
• new victor reinz head bolts.
• genuine GM c20let head gasket.
Brand new cool running 82 degrees c thermostat with polished housing.
Inlet-
•C20let standard inlet manifold, shot blasted and professionally painted in gloss black.
• C20let fuel rail powder coated. Astra VXR 470cc injectors which have been ultrasonicaly cleaned.
• fuel pressure blanking plate with aero quip fuel fitting.
• C20let throttle body, fully stripped and internally polished. Powder coated in gloss black with new tps sensor.
• genuine GM throttle body gaskets.
• standard let top hat Painted in gunmetal grey.
Turbo-
•Hybrid Kkk rebuilt by turbo dynamics, no play in shaft, no smoke or rattles in excellent condition.
• standard let actuator.
• powder coated actuator bracket.
• aeroquip fittings for both oil and water feeds.
•stainless bolts on compressor housing and actuator.
Ancillaries-
• brand new dizzy cap and rotor arm, autovaux.
• brand new K1 ignition leads, 12mm in blue.
• Chris astley rocker breather hose in blue.
• TX autosport afm pipe, standard also included.
• c20let sump acid dipped and painted in silver.
• Nortech performance blanking plate in custom anodised gold, 1 off!
• stripped and painted starter motor in gunmetal grey.
•rocker cover and timing cover acid dipped and professionaly painted in range rover gunmetal grey. Holes cut out for ease of set up on pulleys.
Aluminium spark plug cover, proffesionally panited in high gloss red with polished lettering.
powder coated c20let underdrive pulley in gloss black with stainless bolts
Tx autosport stainless waterbar.
original stainless oilcap, polished.
high quality stainless steel bolts used throughout the engine
high tensile CAT 10.9 nuts and bolts used on weighted parts.
This engine has some marks on it as fitted it two car and will be taking back out once sold. also comes with an f20 5 speed gearbox that has come out off an astra GTE with 98k on the clock. the box has no whines or crunches and works perfectly. The standard c20let engine loom is included in the sale, which has been modified for a corsa.
With the engine being brand new, it will need to be primed before start up, oil pressure showing on gauges and flowing through turbo feeds. i will not be held responsible for any damage upon start up!!
The engine and box is pick up only, it will be on a pallet along with the box. collection is from margate,kent
thanks for looking and if there are any questions please dont hesitate to ask.http://i360.photobucket.com/albums/o...ps1c195fcf.pnghttp://i360.photobucket.com/albums/o...ps40374e35.pnghttp://i360.photobucket.com/albums/o...ps42d82a8d.pnghttp://i360.photobucket.com/albums/o...ps18767ada.pnghttp://i360.photobucket.com/albums/o...ps723246a7.png[URL=http://s360.photobucket.com/user/mcgee/media/null_zpsb3523948.png.html]http://i360.photobucket.com/albums/o...psb3523948.png[/URLhttp://i360.photobucket.com/albums/o...psfa285541.pnghttp://i360.photobucket.com/albums/o...ps7ed2529c.jpg
also for sale meny parts prices we've out postage
quaife lsd for f16 f20 £450
comp mos 15" weve out tyres £250
corsa front mount kit £200
corsa 3" side exit we've tdo5 flange £200
more to comehttp://i360.photobucket.com/albums/o...psc1292b05.jpg
What size are the comps? And ET?
If its the ones I was gonna buy im sure there 5.5 et49
Also interested in et and size of comps
Ill look but think thay r 5.5 et49
As in engine or turbo on ebay
