Seat belt bar
The seat belt bar which holds the bottom part of the seat belt i.e the metal curved bar just below the sill kick plate inside tha car, is loose. Once part of the bar is bolted to the car and the other goes through a hole in the inside of the car.
This part of the bar is loose and I can quite easily move it around and if I tried hard enough I could bend the bar and pull it out.
I have checked the passneger side and that is solid.
Has it simply come out of place or is it worse then that?
Thanx :thumb:
theres a metal sphere on the end of that bar the pops into like a ball joint thing that goes into the shell, youll prolly find that said plastic bits has snapped at some point or its not pushed into the shell fully
Yeah there is a wider point to the bar it does look like it snaps into something. Hmm gona have to go have a look tmoworrow see if it can go back.
Cheers matey
there is a plastic piece that fits into the sill, get the part no. off it & ring the dealer with it....If you go in & say I'd like a thingumy off a nova, most of them tell you no, it is no longer available.
