Help! 1.4i Nova Misfiring
Here is the lowdown:
He starts fine from cold and warm/hot.
- Runs fine at cold till temp gauge gets up onto blue.
- At low revs, on turn into new road for instance in 2nd gear, he jumps and coughs and misfires with loss of power till revs rise about say 2500rpm (Haven’t got a rev counter, so guessing a bit!), when normal power resumes. A good blast in 2nd, up to 3rd, and third higher revs would be ok.
- It is basically at low revs, under load, chronic misfire as if only on 3 cylinders, until revs pick up or load is lightened.
Status of engine: -
- 1.4i Nova, 1991, J Reg
- 45000 miles
- Have had it nearly a year with faultless motoring
- New spark plugs fitted 42500 miles, but now very black
- New HT Lead set fitted 44570 miles
- New rotor arm and dizzy cap fitted 44713 miles
- Heater not very hot in winter months
- Air filter looks clean and new (but obviously over 1 yr. old). No obvious blockages or dust built up areas
Things I still need to check: -
- Rubber inlet hoses in and around air filter to engine
- Clean up and re-check spark plugs
- Fit new thermostat, water pump, and maybe cambelt cause I’ve been told that’s what powers the water pump. This is a major job for me, and hope to complete week beginning 01/07/2013
Any thoughts greatly appreciated.
Cheers
Claire & Marty
