bad boy bonnet
am wantin 2 bad boy me bonnet am doin it me self i dont wanna\ cant afford a body shop 2 do it the bonnet cost me a tenner so if i fcuk it up it dont matter is there ne sites which show u how 2 do it
am also gunna bad boy me boot but i assume thats the same ne help is much appriciated
for toe boot when you say bad boy it do you mean flush it?
If so the easiest and cheapest way is to buy the new style fibreglass panel and blend it in then back fill the gap with expanding foam and fibreglass the underside (unless it comnes with a blanking plate) - otherwise you'll need to weld it and thats an arse!
The bonnets different coz if you slam the bonnet down, the fibreglass will grack. Most people weld a plate across it then fill it flush
You'll also need to relocate the bonnet release catch so you can open the bonnet
Ade
i mean put an eyebrow over the brake lights like nutty nova flair has on his
as 4 the bonnet i wasnt 2 sure if i had 2 weld a plat al the way across or if i cud just make 2 triangular eye brows and wasnt sure which wud look best cos id have 2 losse me grill wudnt i?
LOL @ fibreglassin a badboy bonnet
and the tailgate idea is stupid (imo)
unless u can weld its best left to a pro .. im lucky coz my neighbour can weld he does badboy bonnets d-handling etc .. hes knockin me up a bad boy bonnet for 40quid :P :P :P
bonnet
see when u bad boy a bonnet, do u modify the grill in any way or just lose it altogether? if u get rid of it, what do u do with the spaces at the bottom of the mk 2 headlights?
look at nutty nova flairs his hooks mint i recon!
the grille can stop.
all it is is flushed onto the frount of the bonnet to go over the front of the grille, the bonnent release catch needs to be relocated in most cases, or modded to be extended.
there are cheeper options that are modified grilles that give the impression of the bad boy effect. check out the grilles section on
www.vauxstlye.co.uk
I know
Check out the feature, under Ben & Wills badboy SR.
Are a few parts left for sale.
