I can't afford 90 odd quid for some white rear clusters, so is there any way i can do it for a lot cheaper myself???
Cheers
Matt
Cheers
Matt
1) Use Cluster Paint
2) W**k Off on em :P
3) For tinted effect - wrap a pair of your mums tights round em
Buy a lexus.
Or just do what Anton suggested. Apart from number2. Only i can squeeze out enough spunk to cover them both.
Or, if you must have the genuine article, just keep your eye out for second-hand one's. Somebody might have some.
how does cluster paint work?? surely if i paint over them u wont b able to see any light through them??
also where can i get it?
Well, as far as i'm aware you can't get white 'cluster paint' (it's actually called tinting spray - red/green/blue/black).
However, you can dilute the paint with lacquer and spray over the lights. You might even have to fit brighter bulbs too. I'd leave the painting to a bodyshop (up to ?30), as you need to mix the paint.
Another suggestion is to get 'white' lights would be to buy a roll of those 'go faster stripe' things (?couple of quid, comes in different widths, buy a thin one). Then stick it on the light (going from side to side) leaving gaps the same width as the tape, between each stip. It'll look white from far off, still let light through and is very cheap to do. Though it won't be completely white.
Might just stop being a scrooge and buy some clear rear clusters, at least they will look decent!!!
cheers anyway mate
Matt
I just got some clear rear clusters for my red car and they look the muts nuts, :D :D :D cost ?107 from tuning including delivery and there E-marked www.tuning.co.uk and because there not original GM they have slight gaps in them where the clear meets the black frame so u have 2 seal them with silicone so the don't leak and fook ur electrics !!!!
?107 for a pair of lights that leak :o Not sure if I'd spend that much money on something that isn't finished to a decent enough standard :?Quote:
Originally Posted by SRi 16v
Jim
lol @ ?107, i paid ?70 and they are e-marked and dont leak or enthing like that :D
hmm the tights over lights is becoming more common place now
