Hi guys.
I'm picking up some Nova Sport Webers later on in the week and I was just looking at some pictures of them, and it looks like the vacuum port on 143 is a blank. It might just be the picture, but does that sound right?
Many thanks
Hi guys.
Many thanks
http://thumbsnap.com/t/th20x6zd.jpg
Blank or missing? If missing, probably not a correct carb - could have simply had a cover taken off a 143.
Hi Alex, doesn't sound right, if you need additional pictures let me know, have some carbs loose on the shelf ;)
I'd appreciate that Royston. Are they the old pair that went with the car?
I can see the casting for it and the pipe, but the whole looks blank.
I thought 143 and 144 were the only ones that had vacuum, so shouldn't be a different model.
*hole
Do you think it has snapped off perhaps?
I suspect the vacuum pipe is cast into the body, but I'm pretty sure a solution could be found, with a bit of thought.......
