how do you fit g-max lowering springs and shocks
http://i652.photobucket.com/albums/u...a/DSCF0912.jpg
simply get the old ones off & fit the new ones..
you will need a decent jack, some axle stands, a socket set, and a hammer. a full set is about an hours work to fit...
then get its tracking checked because the wheels will not point straight.
unbolt old items bin the g-max
buy some GAZ
fit and bolt up new items. simples
jack
sockets/spanners
wheel brace
balljoint tool?????????? why?
how the hell do you really think your going to build a rally/track car?
edited out, i was mixing them up with astra ones.. i edited it & put in hammer.....Quote:
Originally Posted by let_nova
lol
easy cos the topmounts are on them already.
jack your car up either do 1 side at a time or both whatever you want.
1. wheels off
2. take the bolts of that go through the bottom of the shock/hub
3.take the 2 13mm off the top mounts from inside the engine bay
with me so far
tbh mate, if you are buying these with out anyidea how to fit them, maybe do a bit of research first.
now im all for new learners, and i wish you the best. but have a read through the guides, and watch videos on youtube, i found some very good videos when i learned how to my suspension. and dont rush it. mowgli says about an hour, which woudl be rushing imo.
just take it easy. i done my whole set in a day. but i had to compress the springs. which you dont have to do.
so simply take of the front, which is 4 bolts. and the rears are 2 bolts. each side that is
just read this.......Quote:
http://www.pngclub.com/forum/showthread.php?t=131331
