Has anyone used one of these yet as apposed to the usual cavalier one?
http://i546.photobucket.com/albums/h...psd2bh5g6d.png
No reason you coulnt make it work, may need chopping and welding though, I went cable in the end
Millworm, can you get the Cable shifter to work on the f13? Or is it a big block MOD? You'll have to show me if it's possible
Id like to go cable but dont understand it lol
New turret on the box, 2 cables attached to a bracket, a hole in the bulkhead & a new shifter.
Everything else is refinement and they can beat synchros.
I'm using a vec c 1800 shifter witch will fit f13 f10 f20 f16 and poss more, had it on an f13 and f20 myself. Just welded up the shifter hole, made some captive nuts to mount shifter. I have the economy skin removed from my tunnel aswell but you can keep it. I used the vectra cable grommet to have the cables exit into the tunnel, out the orginal rod hole in the bay then round to the turret. The vectra cable bracket will only bolt to one hole on the box in my experience but a bit of loctite and a big bar will make sure it never moves. Then set the adjustment on the shifter and your away.
